Posts: 648 |
On the '94 chevy lumina car in my previous post https://vccachat.org/ubbthreads.php/topics/191025/Newer_car_question#Post191025 the gas pedal is still sticky. I cleaned out the throttle body as suggested REALLY good and it did have some gunk but the pedal still sticks. I tryed a little oiling with lite oil around the throttle mechanism but still sticky. What should i think about now?
In my shop, quality is a standard, NOT and option.
Vintage
Chevrolet Club of America |
"The World's Best Chevrolet Club" |
Posts: 828 Likes: 6
Posts: 828 Likes: 6 |
If if you look at the throttle plate with it closed and slowly open it can you see a wear spot where it might be binding. If so you my have to adjust the throttle stop screw. If I remember right the head is recessed and covered, but you can see the threaded part that the throttle stops on. If the head is covered you will have to drill out the plug, and it should take an allen wrench to adjust it. Do not go very far because that is not for idle speed, the idle air control motor does that. You do not need to put the plug back in if it had one.
Posts: 648 |
I didnt see any ware spot but i was looking at that very same screw around in that area and was wondering what if i were to do what you just mentioned. I'll give it a try tomorrow.
Posts: 1,194 |
You may want to unhook the tv cable from the throttle arm and see if your sticking goes away. I've seen those cables bad causing a sticking throttle. Don't drive the car with it unhooked, it will not shift right with it disconnected.
Posts: 648 |
Posts: 648 |
Well looks like turning the screw in solved the trouble. Had to turn the screw in a half turn ti'll it corrected the problem and i still have apropriate idle.
Thanks '41!
Posts: 399 Likes: 1
Posts: 399 Likes: 1 |
Oilspot, glad to hear. Thanks guys for the help. Your Lumina probably has a 3.1 or 3.4 lt. V-6
