Posts: 5,906 Likes: 8
Posts: 5,906 Likes: 8 |
I'm getting ready to install my U-Joint (1931)... I have pieces from two of them to pick from. With the roller balls dry, there is a fair amount of slop when they are on the four spindles. What I'm trying to figure out, is, "how much slop is too much?"
This is something that I don't want to have to replace again later. Should these be "firm" when assembled?
--Bill Barker
Posts: 6,149 Likes: 42
Posts: 6,149 Likes: 42 |
Bill I am not sure about the enclosed type universals but with the open driveline units if it swivels freely and smooth without any rotational play they are generally serviceable. Someone with more knowledge on the enclosed type may correct me. Tony
Posts: 19,758 Likes: 63
Posts: 19,758 Likes: 63 |
Bill, They should be firm but not tight. Most of the noticeable wear will be on the trunnions. The inside of the balls also wear but at a slower rate. If necessary the trunnions can be built up and ground back down. Much harder to work on the balls.
It is far better to get it done now versus later. Loose U-joints and ball assemblies produce drive line vibration and weird noises. When the U-joint wear gets bad enough you can also feel it in the gear shift lever. 600W oil helps to quiet worn parts.
Okay, guys. Thanks... I think that I'd better take this to the next step.
Now -- does anyone know of a good place to get replacements? I looked at Billy Possum's, Chev of the 40's and The Filling Station. No luck. Maybe Moffitts?
--Bill B
Bill, Every once in a while one shows up on eBay. Good used ones are not plentiful. I take parts from several different U-joints (various years) and make up good ones when I need one. Running out of the early ones. I am about to the point that I need to go the machine shop route to repair what I have.
Turning down the trunnions to accept a thin stainless sleeve should be easily done. Just need to find a retired machinist or hobbyist (Bob Hughes?) to do the job.
Oh, the sleeve idea sounds interesting. Never thought of that before. Also, they are not tapered. I can fit them on the shafts using either side.
Bill Barker Previous VCCA CHAT Administrator (VCCA Member: 9802)
Bill Looking at the photo I would be doing the stainless sleeve trick as the pins on the left look worn and I guess the inside of the bushes are as well. I would hone the bushes lightly then sleeve the pins to suit I have seen seriously damaged crankshaft journals that have been "metal sprayed" that have given no further trouble but I dont know what the process is. Tony
Posts: 2,299 Likes: 8
Posts: 2,299 Likes: 8 |
Bill, If you want a NOS one then E-mail me at bwbugay@aol.com
Thanks everybody... I made some progress today... Found a 1932 U-Joint and figured out how to make it work for my purposes (1931). I'll write it up and post it on the http://1931chevrolet.com site. Bruce, I might hit you up for one for my OTHER car! Now that I'm into it, its obvious where some of the "clunks" are coming from. Ha!
And a photo summary of my solution. Bill's 1931 Chev web site Thanks again everyone who responded!!
As I posted above, I have done a similar "repair" several times before. Just make sure that you put the balls on the trunnions correctly so they get the proper lubrication.
For the life of me, I can't see any difference in the trunnion positioning. Can you elaborate? A casual glance didn't find any difference... but I'll use a magnifying glass tomorrow for sure!!
Posted on December 4th: The inside diameter of the trunnion balls, on one end only, has a radius so make sure you put them on correctly.
Posted on Dec 7th: A casual glance didn't find any difference... ha ha... okay, I think that you're saying that one EDGE of the bearing is beveled. Okay - point to Skipper. BUT -- Which side does it go on??!?!?!? ha ha. My abundance of engineering training and common sense would suggest that it goes on the 'outside'.... correct?
Bill Skip probably should correct me but I would put the rounded edge in as that would retain more lubricant for the joint. Tony
I also vote inside to act as a reservoir for lubricant. Any other votes?
Posts: 2,262 Likes: 6
Posts: 2,262 Likes: 6 |
I agree, the chamfered inner radius goes toward the inside, but not because of lubrication. It's that way because the shafts the bearings fit onto have a slightly rounded inner edge (for stress relief probably) and when new, if you put them on with the chamfer facing out, they will bind on the cross. Why they didn't make the bearings with both sides chamfered so you couldn't get it wrong is another one of thos imponderables.
That's my story and I'm sticking with it.
All the Best, Chip
"It's wise to choose a SIX"
Well, dang it... now I wish that I had taken a picture of them today before I bolted them in... BUT, I'll tear the dang thing apart tomorrow just so I can do it. Yes, the trunnion bearing is different on the two sides. Turns out I had three of them facing one way, and the fourth facing the other way. (That blows the law of averages! Ha!) One side of the bearing has a fairly large flat surface, while the other side slopes down quicker and the flat surface is a little smaller. When I matched them to the yoke shaft, the larger flat surface seemed to fit perfectly with the inside face of the yoke shaft. And that would tend to led me to believe that they should be placed against each other?!?!? TRUNNION FACING INSIDE TRUNNION FACING OUTSIDE
Posts: 455 |
I have a question....Are the 33 standard u joint parts the same size as the 33 master?I know the yoke is different,but are all the other parts interchangeable?It seems everyone has u joint parts for a standard,but I haven't found a single one for a master.
Posts: 1,774 Likes: 4
Posts: 1,774 Likes: 4 |
Mike, I have had the same problem, there are all kinds of standard u joints on ebay but never found one for a master. I finally took parts from about 3 u joints and picked out the best parts and it works OK but I would really rather have a new one.
Ed
Posts: 455 |
Hi Ed,thanks for the reply.I have a friend I work with who is a great machinist.We have kicked the idea around for ways to improve this u joint.I know it will not be origional,I am keeping my car as origional as I can.He can machine the yoke ends smaller and make the bushings thicker.Thats 1 idea.We are currently looking to machine the "I.D. of the bushings larger and fit them with needle bearing inserts.What are your thoughts?By the way,you got a nice looking car!Where in Iowa are you?Our parent company is in Marshalltown Iowa.
The original U joints were made well and could last 80,000 miles with proper lubrication. This means not allowing the transmission to run low on gear oil. The 1932 and 1933 Master and 1/2 ton trucks used the same U joints. The 1934-1936 Master had the same joint except for the rear yoke.
Hi Mike, I agree with Gene, there is nothing wrong with the original design of the u joints. The parts are a little hard to come by because of the limited use of just '32 & '33. I am about 90 miles N. of DesMoines and I bought my '33 from Colefax or Colo?( I get them mixed up} in 1979 as a basket case, so not too far from you're parent company. Thanks for the complement on the car, we enjoy it but it is just a driver, not a show car. What company are you with?
Ed
