Thanks, Gene. My unit didn't come with a door unit, so no help there. The sub body is natural, not black - so I guess that's a good sign. I'm not sure I follow you on the adjusting screws/nuts. My 1953 book shows 41-53 ALL taking 4 adjusting screws (P/N 924561), which is 2 per headlight I'm assuming, which is what my '48 has. The nut story is a little more confusing, as it does imply that only 2 are required for 41-48, but if you need 4 screws you would also need 4 nuts. My 53 book has the springs the same for 41-53 ALL if they have the single spring (P/N 5937452) and only 41-47 had two springs per headlamp, so I'm not sure that helps any.
So - if the sub body on the 49 and up is black, that would eliminate my headlamp, but other than that, I'm having a hard time differentiating between the two...
