I did both 216 heads I have here a couple of years ago. One I've been running on the 1950, 3604 and one is on the shelf as a spare. Both got mill work, hard seats, guides, new V8 X-valves, Magnaflux and pressure tested, spring pressures matched and shimmed.
I'm doing the short block this summer, just got off the phone with my engine shop and all they need to deliver it this week is the plugs for the oil galleries. He says they are a real odd ball size and he had to special order them.
Had it bored .020" over, alum pistons from EGGE, rods reworked for inserts, cam brg and timing gear, crank polished and the whole rotating mass balanced.
This past month I picked up a 1954, 3604 (can't seem to get away from those 3/4 ton trucks) that was a virtual one owner. In fact the guy that owned the truck up till this summer was a 14-year-old farm boy from central Nebraska in April of 1954. His dad bought the truck for him to drive to High School because there was no bus service out in the country back then. Of course the truck also had to carry its weight doing farm chores. This engine is the one that raised the questions about the 3836913 head. I haven’t had the truck long enough to do a full evaluation of it. It runs nice, needs some front-end work and a good clean up and eventually will get all of those dings and dents removed. It was garaged most of it’s life and the only rust is small hole at the drivers cab corner were there were some rags and dirt that had accumulated there.
I’ve got a book of receipts from 1954-6-7 for delivery of hogs and cattle in the dad and son’s name and a hand full of registrations over the years. It has most of the original paper work in the glove box, i.e., owner’s manual, service policy, break-in/tire chart card certificate of title. He said they registered and insured it in his, (the son’s) name back then because it was cheaper than having it in his dads name. The real kicker is the guy is ’70 now and lives a mile away from me and says he has pictures of the truck being used on the farm.
http://www.pbase.com/dennygraham/1954_3604_chevy_truck&page=all So I’ve got a good starter for the next project after the ’50.
Denny Graham
Sandwich, IL
