Posts: 38 |
Found a good Chev day/night mirror at Portland Swap Meet but the mirror needs re-silvering.Any one know who would still do this?Can't find anyone here in Victoria that can.....Thanks
60 years of golf,never a hole in one.
Posts: 38 |
Hi Skip.Mirror's all apart and being rechromed as we speak but because of the tapered glass to make it day/night the local guys don't carry such a thing(glass is thinner at the bottom than it is at the top).
Posts: 10 |
I didn't know that's how it worked. You might find a newer one in a junkyard that could be cut down to fit...
Posts: 10 |
Found a page with instructions on doing it yourself. Mirror Silvering Mike
Posts: 598 |
Wow! Sounds like a big and expensive job. Silver Nitrate is expensive. Let us know how It turns out if you attempt It. Richard
Posts: 287 |
1936 Low Cab Pickup
Posts: 38 |
I took the old mirror with me to a local wreckers and after a little searching, found a day/night mirror in a later model Acura that was almost the same size for $10.I used a Dremel tool to cut the plastic case off and took the two mirrors to a Speedy Auto Glass shop that trimmed the Acura one to size for $5.for the coffee fund.Put everything back together and it works perfectly. Thanks to everyone for all your help.
