Posts: 110 |
Can you help--does it make a difference to run the hot wire to the light switch then to the light? --also which posts on the dash board switch?? Thank you
paul orednick 305 canal st lemont Il 60439
Posts: 110 |
I am sure the first wire you refer to is connedted to the light switch in the dash. Right?
