I have a 1933 Master Sedan with dual horns. I can't get both horns to work at the same time. If I connect either one separetly they will work. Is there something special I need to do to get them to work together?
You need to check to see if you have enough voltage to work both together. You could have a poor ground or a voltage drop on the pos.side. Check to see if they will work together if you hot wire them right off the battery.
