Posts: 21 |
The harmonic balancer is made up of 2 parts,riveted together by 4 big rivets. I have some play between these parts. Is this normal or are these parts supposed to be tight together???. I hope I'm making clear. Thank you folks; Well appreciated.. Hotpockets
Posts: 2,299 Likes: 8
Posts: 2,299 Likes: 8 |
I would say they should be tight together.
Posts: 2,576 Likes: 2
Posts: 2,576 Likes: 2 |
if there is rubber sandwiched between the two metal pieces of the 32 chev harm balancer(like small and big block chevy engines) you can have it rebuilt. there is a guy who ads in Hemmings motor news who rebuilt the harm bal on my 32 dodge 8 cyl (couldn't find replacement for the dodge--had to have it rebuilt). before resorting to having the hemmings fella rebuild it, i tried injecting silicone between the two pieces to replace the missing rubber which had fragmented. i got about 2K miles out of my bandaid fix, then resorted to having it done professionaly. am pleased with his work. good luck, mike
Dawg: how do the 32 harmonic balancers work. i understand how the SBC and BBC balancers work with the rubber insert. are the rivets a loose fit?guess i gotta do a 32 when the 31 finished. mike
Posts: 11,162 |
maybe one is a Balancer and the other is a Balancer & Dampner?
Posts: 19,758 Likes: 63
Posts: 19,758 Likes: 63 |
I must check to be sure but I thought that the '32 balancer had rubber around the rivets and between the washers that held the two pieces together. Been wrong before so could be this time too. Once I check I will know for sure.
Chevrolet info. from that time mentions leaf springs in the balancer.
There is an excellant cross section view of the 1932 and new 1933 balancer in the 1933 Engineering Features book.The outter hub is attached to the inner by the pins or rivets that show on the exterior.The springs wrap around the pin -
At the end of the description of the new heaiver 1933 balancer they note "The harmonic balancer unit is tuned to 135-150 cycles per second to reduce the amplitude of the natural frequency of the crankshaft"....thats pretty hi-tech for 1933.
Even the new more complicated balancer for 1937 uses the spring mechanism.
The 1939 info. describes "a completely new harmonic balancer" that is "floated in rubber" replacing the former which "had a flexing medium that consisted of a number of a number of small flat type springs".
After a few years the 1939-40 balancer replaced the 1937-38 when a new one was purchased thru the parts dept.
By golly I think he got it. I think he got it. Thanks Gene for resurrecting my memory. Looking at the ’33 Engineering features booklet helped too. Guess I had the use of the rubber-isolating layer on modern harmonic balancers too indelibly etched into my synapses. How’s that for some $ 5 words and the reference to "My Fair Gentleman"?
Posts: 221 |
So did the 32 balancer have springs? You said the 33 had springs.
Yes, the 1932 had springs - the 1933 springs were just larger.The springs can not be seen but the four pins/washers that retain them can.
Posts: 566 |
Does the 31 have a harmonic balancer????
Four doors are great
Hoppy
Posts: 988 |
Yes Chevrolet p/n 363354 fits 1930 & 1931 all.
Posts: 566 |
35 pickup man!! THANKS!!!
Hoppy
