Posts: 96 |
Is there more than one source for a 1929 wire harness? If so, which one is recommended? Or, where might I find the correct wire and connectors to fabricate my own? Bill
Bill
You can get a wiring harness from the Filling Station in Lebanon, Oregon, www.fillingstation.com/ or from Rhode Island Wiring Service in Rhode Island www.riwire.com/ or from YnZ's Yesterday's Parts in California www.ynzyesterdaysparts.com/
Posts: 2,157 |
are they all made by the same manufacturer, or, if not, which is most authentic?.. epi
Posts: 377 |
I purchased sets for 1929 and 1931 from YnZ and was very pleased. I had the original in the 1929 and it was copied down to the armour wrapped wires for the headlights.
Doug
Posts: 3,542 |
Posts: 96 |
Do they include the short piece of armor that covers the wires going to the generator and temp sensor? Also the armor for the tail light that runs between the body and the spare tire rack? Bill
Bill
Posts: 19,758 Likes: 63
Posts: 19,758 Likes: 63 |
The '29 and '32 are not the same but basically only differ in the length of a few wires (tail light, gas tank, horn) and the tail light plug or terminals.
Posts: 3,542 |
Since most of the replacement wiring harnesses did not have the original type armor or conduit it must be replaced or added. I also have a '29 harness that I will use on a '31 after making the modifications. Any of the harness suppliers can also supply wire.
Posts: 3,542 |
Posts: 509 |
Can a new harness be put in without a complete breakdown of the car?
Posts: 96 |
Junkyard, thanks for the info. Bill
Bill
Posts: 509 |
Gator or Chipper, if either of you still have your '29 harness intact, maybe we can make a deal and you can just buy the right one. Did either come with the correct Chevy terminals?
Posts: 184 |
The wrapped armored cable was used in 1929 and early 1930. In late 1930 and up the larger flexible headlight armored cable was used. What is the difference between the two? What would be the dates to determine the early 1930 from the late 1930?
Seeing the USA in a (1930) Chevrolet
Posts: 3,542 |
