#150308 08/20/09 10:39 PM
PAPA-K Offline OP
replacing front coils, trying to get new one compressed enough to get spindle bolted back in, bare frame and engine trans installed for weight, using homemade compressor i built any tricks anyone has? not going well here thanks
Wilwood Engineering1955-1957
Can't help much if you are using a homemade compressor as I don't know how it is made and works. I have two different ones that both work but one is much easier, the other more secure. I use the one that I consider safer as I don't want to launch a coil spring across the shop or into my body.
All that is necessary is to compress the spring ~25%. Put it in place and then use floor jack on arm to get spindle to line up. It can be done by hand but much easier with jack.
PAPA-K Offline OP
the one I am using is a rod that goes tru the shock mount on top a bar 3/4 down tighten the spring up use jack Im just not there yet, yours sounds easier,
PAPA-K Offline OP
Those springs are in, one I did twice (of course) never want to do that again! iagree willy yay beer2 beer2
