Posts: 91 |
I have removed the mat from my running boards and find there are four depressions, one in each corner where the braces are attached. Are these supposed to be there?
Posts: 19,758 Likes: 63
Posts: 19,758 Likes: 63 |
Yes they are made that way. The original mats were molded to the boards which filled the depressions. If a glue on mat is used these depressions must be filled with a body filler then the mat glued in place.
Posts: 91 |
Posts: 2,576 Likes: 2
Posts: 2,576 Likes: 2 |
filling station out of board mat for a 31. anybody got a source for the mat? thanks, mike
You can try I&I Reproduction in California, but you will probably get the same response. :( :( :(
