Hi everybody here.
Bought an original chevrolet car heater 1931 for my Chevy Independence 1931 at ebay.com.
Began to restore it now to add it to my car, but I dont understand why the fan motor does not run with 6 volt system. Everything looks original and untouched at the heater I bought. And 1931 there were all cars with 6 volt system, so how it is possible it is a 12 volt motor there? I did check the brushes, they are good. As well the armature. The bearings were good too, just dry. I did lube it, the rotor turns easy now. It should work and blow with 6 volt I guess, but it does not. Connecting with 12 volt gives a good blow without overheating the motor, so I think 12 volt is the correct voltage for this motor. I am really confused about that miracle.
Other question: As I understand the construction, the fan should suck the air through the honeycom radioator on bottom of the heater and blow out the heated air at front. But, correctly connected, mine is working opposite, sucking the air on top and blowing out at bottom. That cannot be ok I guess.
Any ideas about my questions?
Thanks, Stefan from germany
