Posts: 148 |
Do any of you have your car apart to where you could give me some measurements for the windshield regulator mounting board? I just need to know how thick, wide, and a reference point to mount the regulator.
Thanks Steve
Steve
Posts: 148 |
I do realize that it can be purchased for a nominal fee. I am a master craftsman and have all the expertice to fabricate one even if it is from scratch. I just thought I would try to save some frustrations if anyone had one out where I could get some measurements. I am retired so time is of no concern. I have already re-wooded (2) doors + regulator boards for them, (1) door post, and back seat springs board. I do sincearly appreciate all advice, and realize that everyone is trying to save people a little time and frustrations, but I do relish a challenge. That is what makes me tick.
Thanks Steve
Steve
Posts: 1,290 |
Is the 32 the same as a 31? If so I could help you out. I have a new one from Rodman that is not installed.
Posts: 148 |
If I am not mistaken, JYD said they were different. The crank was located in a different place. Please correct me if I am wrong JYD. I am working from nothing, so I don't even know how it is suppose to look.
Steve
They are different. :( :( :(
Posts: 89 |
i have a spare for a 31 coach
Posts: 499 |
Hi Steve,
I think a lot of these guys can't do their own work and are embarrassed when you ask a question concerning measurements. I have a new board for my 31 Coupe and will give you the measurements for it if you would like.
If I knew how they are different from the 32 I would tell you but I don't.
JOHN GILL
"I think a lot of these guys can't do their own work and are embarrassed when you ask a question concerning measurements." Why would anyone be "embarrassed" about giving out measurements if they have the material item in hand to measure? And, many of the fellows on this site actually do their own work as you can tell from many of the postings concerning the work that they do. The problem is that the 1932 regulator must be out of the car so that measurements can be taken. If someone has a regulator not mounted in a car, then I'm sure that they would be happy to get the measurements for Steve. "Embarrassed" has nothing to do with the issue. Again, both the 1931 regulator board and the 1931 regulator are different than the 1932 version, so Steve needs the measurements from a 1932 regulator board. :( :(
Posts: 499 |
Thank You JYD,
I was just trying to get a clear explaination as to the difference in the two boards. Sometimes when you GOAD you get the response you wanted.
Sometimes Not!
Its an old investigative technique. Your right," embarrased", has nothing to do with the issue.
JOHN GILL
Posts: 103 |
31 board is different from 32 . i lent my 31 to a fellow to copy for his 32 .they are not the same .kozy2772
Tom Koziol
Posts: 91 |
I believe I can help. Let me know what you need. Steve
Posts: 126 |
Steve: A detailed drawing is in the mail to you
Posts: 148 |
Thanks to all of you who responded. I have one made now. Regulator is on and it fits the car like it was supose to. Thank You
Steve
Posts: 316 |
Steve, Sometimes it takes a while, but eventually someone will actually get around to answering the question you asked. :confused:
Regards,
See the USA in a Vintage Chevrolet
