#139863 03/27/09 11:35 PM
I have two broken clips that were holding the aluminum molding
along the rocker panel on the driver side. They are about the size of a half dollar and made of plastic. Filing station has nothing nor does Impala Bob. Anyone know where they might find these.
This would be a 1965 Impala Convertible
Last edited by southtown; 03/27/09 11:53 PM. Reason: did not identify type of vehicle
Wilwood Engineering1955-1957
southtown #139866 03/28/09 12:16 AM
KO , try Restoration Specialties supply:
Their online catalog is at: Restoration specialities catalog
It is a pretty long (4.70 MB) file and may take a while to load on dial-up.
Their phones are 814 467-9842 & 814-467-9282
web site is http://www.restorationspecialties.com
snail mail is:
PO Box 328
Windber PA 15968
Good Luck! beer2 patriot :vcca:
P.S. KO when you get to the catalog, the Rocker Panel fasteners are starting on page # 127 and the table of contents starts on page #222 Look on page # 130!
southtown #139884 03/28/09 03:34 AM
Check your local paint supply shop. They have the circular racks full of all types of fasteners and clips. You may find something that will work.
Agrin devil
thanks, I 'll try this possibility Monday.
southtown
southtown #139956 03/29/09 01:45 AM
Thanks MrMack, I found the clips for the molding on the rocker panel on page 130, top of the page, in the center, the round ones. I appreciate the help, need a place to stay the next time you are in DFW, I feel obligated to reduce our over night rate by 2%. southtown
southtown #139963 03/29/09 09:37 AM
Golly, KO, only 2%, well that is a good rate anyway. Just give the guys ar Restoration a call. You don't need to be driving that 65 around with a loose rocker panel!
