#139649 03/25/09 05:58 PM
Looking for pictures or illustrations showing the inside workings of the door glass, behind the window regulator. I am not using any wood in the doors. With the window smaller at the top then the bottom, when the window is rolled down it tips ahead. When the window is down the only part of it that is in the channel is lower front corner. Jim Carter has window patterns, but has yet come up with the correct sizes. Their working on it ! It goes up great. Easymoney.
easymoney
on my 34 i had the same problem if i remember i used a spring to hold the glass in the track . a one arm regulator is what the problem is . hope this helps
