Posts: 201 |
Making this post smaller..... 08/22/05 Old Online Chevy Manuals for Pre & Post War Chevrolets http://chevy.tocmp.com/ Over 67 complete manuals and other info.
Posts: 201 |
Hi All, Continuely adding manuals to the Old Online Chevy Manuals site.
Chev 4 cyl casting numbers Note: I have tried all the tricks in my bag and can't get this to maintain chart grids, so read it carefully and you will figure it out. Credit is given to Dave Taylor of South Africa for providing this data and permission to post. CYLINDER BLOCK CASTING NUMBER IDENTIFICATION Year Model Casting No Part No 24 327772 25 Series K Before February 334653 25 Series K After February 344624 26 Series V & X 345505 27 348709 28 348532 CYLINDER HEAD CASTING NUMBER IDENTIFICATION Year Model Casting No Part No 17-19 DV8 338048 22 FB Three Port 381099 16-21 333776 21-24 Aug1921 … Nov 1924 327773 24-26 Dec 1924 … March 1926 344128 26-27 Mar 1926 … June 1927 Single Port 1 ½ inch Valves 345453 27 June 1927 onwards Single Port AA LM 1 21/32" Valves 346886 28 Two Port 348540 36-51 With fan (for low speed driving) 602253 604486 48-52 With fan (5” dia. pulley) 1911990 TRANSMISSION CASE, Year Model Casting No Part No 16-21 14181 25 590204 26 590219 28 590321(F 13 8) 590328 590279 (I 8) 353300 TRANSMISSION CASE COVER Year Model Casting No Part No 16-21 14182 25 590061 27-28 590281 590034 TRANSMISSION U-JOINT CASE, Year Model Casting No Part No 16-21 25 27-28 590182 TRANSMISSION SPIGOT SHAFT PLATE Year Model Casting No Part No 16-21 25 27-28 590211 DIFFERENTIAL PINION, Year Model Casting No Part No 16-24 Chevrolet, 490, Superior, Passenger & 1/2 ton truck ratio 33-9 ratio 34-9 25-28 Chev. K, V, X (67mm Dia) Ratio 42-11 344025 29 Passenger & 1/2 ton PU, A-6 (70mm Dia) Ratio 42-11 355414 DIFFERENTIAL CARRIER ASSEMBLY, Year Model Casting No Part No 26-28 344031 DIFFERENTIAL CASE, Year Model Casting No Part No 26-28 344021
Originally posted by Oldie: Okay, The following covers the time frame being discussed.
1 = Flint 2 = Tarrytown 3 = StLouis 5 = Kansas City 6 = Oakland 8 = Atlanta 9 = Norwood 14 = Baltimore 20 = Los Angles 21 = Janesville
In 1953 The serial number system, with reguards to assembly plant identifiers, changed. The 1953 serial numbers looked like this:
53A = Atlanta 53B = Baltimore 53F = Flint 53J = Janesville 53K = Kansas City 53L = Los Angeles 53N = Norwood 53O = Oakland 53S = St. Louis 53T = Terrytown
Over the years the Plant identifiers changed due to assembly plants being added along with the mix that came as a result of GMAD being formed.
A = Lakewood B = Baltimore C = Southgate D = Doraville F = Flint J = Janesville K = Leeds L = Van Nuys N = Norwood R = Arlington S = St. Louis T = Tarrytown U = Lordstown V = Pontiac W = Willow Run Y = Wilmington Z = Fremont 1 = Oshawa (yes, that's a one) This information was 'borrowed' from another thread and placed here for the record.
Posts: 354 |
What a great list. Thanks Michael41
Michael
Posts: 6 |
where was serial number on 31 chev 4 dr sedan??
ALLEN MCCALL
Posts: 326 |
Passengers side body sill under the floor mat.metal plate about one and half by three inch with serial stamped on,fastened down with four small tacks.
woody
Posts: 95 |
Posts: 95 |
Posts: 377 |
Bow Tie Reproductions would be good to add to the list. Dale Wahl is excellent to purchase from and always backs up what he sells. www.bowtiereproductions.com ph:440-327-4800
Doug
Posts: 92 |
_________________ Perry A. Seaton pseaton@kc.rr.com
Posts: 30 |
some of these links seem to have been hijacked.
The first link was posted nine years ago. The second link was posted seven years ago but it is still current.
Posts: 3,620 Likes: 5
Posts: 3,620 Likes: 5 |
I sure wish David Hayward's links were still working. A lot of good info lost there…
Posts: 19,758 Likes: 63
Posts: 19,758 Likes: 63 |
I expect that Ken Kaufmann who was co-author with David on some of the websites would have copies of much if not all of the data. Ken (Pre25Chev4) doesn't frequent Chat as often lately (last post June 2014). Maybe someone could ask him if they already know.
