Posts: 570 |
Has anybody ever used a Mallory Dual Point Distributor. And if so, have any Idea as to the function of the advance mechanism. It appears as if the mallory advances, where the stock retards. Hmmm
Posts: 11,162 |
I used the Mallory dual point distributor, don't remember there being any difference in the advance and the Delco, In fact I think I used the original vacuum advance. i have also used the Mallory dual point plate replaceing the original one in the Delco distributor in Chevrolet 235 and 261 engines.
Posts: 570 |
Thats kinda what I did. I made a new plate to fit the mallory, and used the bottom of my delco advance. It works well, but it just appears that the mallory has a real advance, and not a retard. It's perplexing. Being that I run 88 octane, I like to have plenty of advance. After having my head shaved 2 years ago, it is about 6.8 to 1 compression. (wow) Maybe I should leave good enough alone.
Posts: 570 |
The reason for my whole bringing this up was, I am working on a homebuilt 6volt MSD (Multiple spark discharge) It works on my bench setup right now, but it is obvious that it needs a bigger condenser. Probly won't work right on a car, but, my brain needs exercise from time to time. So it is fun to get away from the wife and built stuff from ground up. Maybe I will build a time machine next, and go back before I got married and get my head looked at...
Posts: 1,866 |
:whistle:
Posts: 11,162 |
After having my head shaved 2 years ago I haven't done that since USMC bootcamp .....but every once in a while I think about growing a mustache!
Posts: 570 |
I had a funny feeling that Mr.Mack was going to jump on that one. Even as I was typing it, I was trying to phrase it so that it couldn't be twisted. :grin:
Posts: 11,162 |
Yep, That was one I couldn't go by without a grin.
