Oil leakage on the rearmost main bearing.
Oil spill on a the rearmost main bearing can be owing to for small autflow a the rearmost nether bearing.
Do i discovered my oil leakage, a i'd mounted a new gearwheel oil pump, a gives important more oil from the old original oil pump, a couldn't run quickly enough backward in sump, so that do i dismantle the the rearmost main bearing pan, and took the freeze plug of, and so that to a hole which was, a was one 6 mm. the drill slanted down, back-and forth.
Do i drilled the 2 holes up to 10 mm. and placed plug in once again, after that zero oil leakage.
