#11976 02/28/05 04:38 PM
RGwiz Offline OP
Does the rear window in a Sport Coupe crank down all the way, or is some of the window still visable when it's in the down position?
I just finished installing a partial wood kit and had to remove the window glass and water trough. The window used to go down about 90% so only about an inch or so was still seen. If that's correct then can someone check thier's and let me know how much is still showing when it's cranked all the way down.
Thanks, Ray.
Chat Group Chapter Member
Current rides;
1968 Camaro rs/SS 350 4spd
2000 Blazer LT
2005 Malibu Maxx
2007 Acura TDX
Last total restoration;
1932 Sport Coupe
#11977 02/28/05 06:36 PM
The rear window cranks down all the way on my '32 Sport Coupe.
Chevybill
"Listen to the Roar of a Chevrolet Four!"
#11978 02/28/05 07:00 PM
RGwiz Offline OP
Thanks ChevyBill.
A long time ago my Dad repaired the wood around the window. I think he mounted the trough too high on the wood frame so the window bottomed against the trough.
My only reference is the 29-32 Fisher Body Manual and it shows a 29 or 30 in the photos. It is of some help but not clear enough to see what is going on.
If anyone has this area open, give me a dimension from the top of the wood at the window opening (bottom center) to the top of the metal pan that is connected to the trough.
Thanks, Ray
Any help from you guys would be great.
Current rides;
2000 Blazer LT
2005 Malibu Maxx
2007 Acura TDX
1932 Sport Coupe
#11979 02/28/05 08:44 PM
Mine cranks all the way down. Taking a quick measurement, in the trunk the bottom of the trough is about 8" below the wooden crossmember.
FDNY
#11980 03/01/05 02:50 PM
RGwiz Offline OP
Thanks Bob, I replied to your email.
Current rides;
2000 Blazer LT
2005 Malibu Maxx
2007 Acura TDX
1932 Sport Coupe
