Posts: 11,162 |
Mike, I don't know why the difference, here Diesel runs 25 to 30 cents higher per gallon than unleaded, and it has been that way for a couple of years.
Posts: 5,906 Likes: 8
Posts: 5,906 Likes: 8 |
wow... good job cropping the photo... you beat me to it!
Good.. that gives me more time to work on a new posting for the Members Only section on the web site. Look for it on Sunday!
Bill Barker Previous VCCA CHAT Administrator (VCCA Member: 9802)
Posts: 11,162 |
This is a bit off topic, but it may be the place to ask about the color of turn signal lamps most of you think I should use on the rear and the front of my 1928. The Filling Station has them in both amber and red. I am leaning toward red for the rear and the amber for the front. I considered using the cowl lights for front turn signals but I don't think their placement up on the cowl will be effective. I don't plan to have the car judged. It has a decent body and drivetrain but the interior is original and worn. It is a good touring car. I intend to make brackets and mount the lamps a couple of inches above and behind the bumpers both front and rear. I probably will also use the rear lamps as brake lights, with the original in its proper place in the middle of the spare tire. I think one of the LED 3rd brake lamps will be a big improvement in the safety of driving old Klinkerbelle. Giving hand signals just don't cut the mustard in the 21st century, every one thinks I am waveing hello to them, or worse....then I suppose it won't be too long until I install seat belts.
Posts: 1,411 Likes: 7
Posts: 1,411 Likes: 7 |
Mack: That is the color choice I used for the recent addition of turn signals on Old Blue ('37 half ton). It seems to work fine, so far. I too had interesting experiences with the hand signals and near miss collisions. I made brakets out of .25 inch thick sheet aluminum then painted them black. 37Blue
Posts: 11,162 |
Thanks 37Blue, I have some aluminum strap about 1/4" thick by 1 1/2". That should work for the 28. If I do use them for combination turn signals I guess the rears better be red. I need to turn in an order for the filling station for some of their nice 6 volt lights and a socket for the turn flasher, I got a nice turn signal switch on eBay. I haven't seen one exactly like it. It has a green bullet shaped pilot bulb on the end of the turn handle. It was pretty good for the $9.95 minimum bid.
Mack: I looked a long while for front lights that would look "period correct". One of my buddies suggested I look at Harley Davidson (HD) motorcycle turn signal lights. They turned out to be a near perfect miniturized version of the bug eye head lights on Old Blue. I went to a cycle shop and found non HD brand lights with the same look for a fraction the price of the HD lights.
Hope you have an easier time wiring the switch and lights than I did. You might recall my posts from last Fall seeking advice. Learned a lot, but what a hassle for a neophyte without a wiring diagrame for the truck and incomplete switch wiring instructions.
37Blue
Posts: 4,951 |
... If I do use them for combination turn signals I guess the rears better be red... It seems like rear turn signals on modern cars are amber or yellow. That might look better - and - be more visible also. Just a thought...
Posts: 11,162 |
Yes, but I should have said combination turn signals AND STOP LIGHTS, I was told that the turn signals are amber only if the red stop lights are seperate lights.
Posts: 11,162 |
37Blue, thanks for the heads up. I have also looked at Harley Davidson and other motorcycle lights. J.C. Whitney has a very nice variety, square, round, bullet in chrome and painted, with minature visors and even some with a metal lens guard with slots or louvers. They are a dollar or two less price than The Filling Stations, but they don't come with six volt bulbs, that would require changing out the 12 v for six volt, and I like the way those at The Filling Station look.
Posts: 1,197 |
As a final report on my first listing regarding 3 rd. Brake Light.
I got it, it's cool, well designed and I will be installed this weekend. And the people I contacted could NOT have been more helpful and nice.
And I have Ray & John348's number handy, just in case.... Michael41
Posts: 238 |
I second Mike's thought on this firm. I just ordered one and the owner couldn't have been more professional and helpful. He took the time to give me some hints on installation. He also gives you a week before he charges your credit card in case you are not satisified; and if it ever breaks, he will replace it.
Thanks all who took part in this discussion.
David
David
Sunbird advice: When the temperature outside is lower than your age, it is time to head south.
Hubris is as hubris does!
Posts: 238 |
Mike. While I appreciate your thread on brake lights I can't let your blaming the oil companies for your high price of gas and diesel pass without comment. The higher prices you pay for gas and diesel in CA is due to California's high taxes and strict regulations --- which are in addition to the Federal taxes and regulations (including the mandated new diesel fuel which is much more expensive) that the rest of us pay. Bottom line is that the states and the federal government make more off a gallon of gas than the profit of oil companies on a gallon of gas.
David
Posts: 1,197 |
Dr. David....Umm, it appears you missed the last statement I made: "Can't complain however, bought oil stock 2 years ago." And I speak of profit as a good thing especially when I get my dividend checks. Interesting fact {Via Stanford Business School} "Never before in the history of American biz has one industry profited so well on it's investments and products {as Oil Co.}." From my perspective, that's just good old american ingenuity at work and working well. Yes sir, Ol' Sam Walton would be proud. But thanks for the California tax & economics lesson. Always nice to know there are people in the know. Enjoy the ride, Michael41 aka: Dr. Mike
Posts: 238 |
I did not intend to suggest that you were anti-capitalist, and I am sorry if you took it that way. As one who owns energy equities and options, I, like you, more than pay for my gasoline (for 4 vehicles) from these investments. While I did read the part about your dividends, I just thought the comment about your high gasoline prices compared to other states, and putting blame on oil companies, was neglecting the most important variables in the price of gasoline (not just in CA) and that they are government regulations and taxes. Just wanted to make sure the oil companies didn't get all the blame. The large difference between the price of a gallon of gas in LA vs here in Scottsdale, AZ is not due to the oil companies.
And let's face it, a major part of so-called oil companies' profits come from products other than gasoline; and in many cases, the majority of the profits come from outside the United States. Actually, given all of the above it contantly surprises me that in most places gasoline costs less today (inflation adjusted) than it did in the 1970's.
I wonder if Stanford ever heard of Microsoft. Last I read, Microsoft's ROI and profit margins were far greater than any oil company's.
Again, thanks for the topic on the third brake light. I bought one and look forward to receiving it. I have seem them before but until I read this thread, did not know they came in 6V.
Remember, even Maynard Keynes later in life came to agree that Ludwig Von Mises was right about capitalism.
Buy low, sell high, and keep on truckin'!!!
David
David
Posts: 11,162 |
Yes, oil investments have worked well for us. We took a pretty good hit right after the Enron fiesco but instead of cussing about our losses we bought more. I put my earnings into my 401K, no company or Union pension scheme, no rollover. Our investments went from $48/share down to $26/ a share, so we bought a bunch of $26 shares,..... sold our used to be good stuff like GM and Ford...and added to our mineral rights, which we bought from unhappy royalty owners. and now we are ok until the next big drop in oil prices. I am not too worried since I have based my profitability on $20 a barrel oil. If I die penniless it will be my fault, not a union organizer or a slick shoed, bright tie money guy, after all it happens in the best of families...It is a no-brainer for me since I am 3rd generation oilfield. Need I say the "H" word (Halliburton). Just ask your self...Who owns the oil companies? Why not me?
Besides at my age, it does not take a lot to make me happy, reasonable good health (I didn't see my name in the Obits this AM), Medicare! because the government will take care of us, a smile from my female pard and our grown brats, and them grandchildern', a smooth running Chevy six or four, a good cold margarita, a burned piece of a fattened steer's butt, with a baked tater, and a bowl of banana pudding and that is about it! The simple life.....Giving more than you receive....You can't take it with you........
Posts: 238 |
Good post. My cousin owns a company in Houston that sells valves that measure flow to the oil industry and others in US, Europe, and South America. When the price of oil is up, he sells valves, when it is down, he plays golf and waits and hopes his money lasts. A lot of people today do not remember when many companies had to cap off wells because they couldn't even cover variable costs.
I totally agree about self-responsibility. If it broke, I broke it, not society.
We often spend part of Spring in Texas. One of the great states.
David
David
Posts: 6,149 Likes: 42
Posts: 6,149 Likes: 42 |
It is not only the US governments (state and federal). Here in Aus between the 2 levels Goverment ends up with 70% of every $ spent on fuel. Tony
