Posts: 350 Likes: 1
Posts: 350 Likes: 1 |
Trying to find out exactly what year Powerglide I have. I did a little researching, but couldn't find what I am looking for. I need to know which numbers to use and/or where the date code would be.
I believe it is a '63 trans, but not sure.
It is Aluminum.
Any info would be appreciated.
Bill
The numbers could be found in the following locations -from my info. 1962 - stamped on machined surface on lower right of case. 1963-65 - stamped on bottom of oil pan. 65-69 - stamped on right side of oil pan. Typical number would be - C 11 16 N The C indicates made in Cleveland 11 16 - made Nov 16th - N is the shift. Year code not used.
Sounds confusing but thats the way the parts book reads.
Posts: 350 Likes: 1
I'll give it a try.
Thanks for the info.
Bill
