Posts: 1 |
I have recently acquired my granfather's 1948 Stylemaster. While attempting to restore it to original, I noticed that it looks like there may have been a reverse light on it at one time. I have not had any luck in finding a replacement. Any ideas?
Hi, The back up light you are looking for will have a pedestal attached to the body under the tail/stop light. On the end will be the backup light. I have seen them at swap meets and on ebay. You will have a dark brown on/off switch located under the dash and on the edge. The handle will be labeled "BACK". Perhaps some of the 1942-48 fans on the sight may have a spare.
Posts: 3,578 |
I have the backup light and a n.o.s. switch for my 48 fleetline.although I have challenges getting it to align with the shifting mechanism??Dought if I will ever hook it up,chef...p.s.a working switch is quite hard to find,good luck
Posts: 210 |
This is a little off topic but related also. did the '42 to '46 have a diff. back up light? Was it not rectangular and the same design as the rear tail lights? I have seen them on ebay and go for ridiculous amounts of money but have never seen them on any cars in pictures or other. There is a diff part# listed for 42 and 46 and the discription of measurements sounds about right for the lense and bezel. Just wondered if I'm blowin wind or not.
'46 Fleetline Aerosedan Most southernest vintage Chevy owner in Canada.
Posts: 437 |
I saved the box that my '48 backup light came in. It has a switch that goes on the shift linkage on top of the steering column in the engine compartment. The backup light has a mounting bracket that is mounted between the left tail light and the trunk opening. The light is round and has the Guide # B31 at the top. The shell and bracket are chrome. The bracket is mounted to the body using a rubber mounting gasket. The light makes a right angle with the bracket...... The bad part is that you have to drill three holes in the body to mount the bracket. One is for a dowel, one has a bolt and the other one has the wire....group 2.697 part #986095
