Posts: 214 |
I remember back in the 70's there was an additive available for positraction rear axles. Is this still necessary, and if so, where can it be purchased?
Willwood Engineering
Posts: 1,894 |
It still exists. Dealer, Amazon and many others sell it. Some synthetic gear oil contains it already (I think Royal Purple and Lucas?)
It's added to prevent chattering clutch plates in the posi unit when turning.
1938 Canadian Pontiac Business Coupe (aka a 1938 Chevy Coupe with Pontiac shaped front sheet metal - almost all Chevy!) 1975 4-speed L82 Vette
Posts: 30,699 Likes: 141
Posts: 30,699 Likes: 141 |
Can be purchased from a GM dealer under part #88900330.
Posts: 214 |
Posts: 2,142 Likes: 3
Posts: 2,142 Likes: 3 |
I found that for some reason the only stuff that works is the GM additive, I don't know the exact reason as to why the other products do not work well. Every time I used them I had to remove the fluid and go back tot he GM additive, the clutches were locking up
John
1954 Belair Sport Coupe 1960 2 door Impala Hardtop 348/340HP 4spd 1962 2 door Impala Hardtop 409/409 4spd 1962 2 Door Biscayne Sedan 327/250 Auto 1977 Monza Mirage 305 4 Speed 1988 Celebrity Wagon 2018 GMC Sierra 2500 HD Diesel
The GM brand is the only one that works.
Posts: 3,467 Likes: 48
Posts: 3,467 Likes: 48 |
My experience is the same. 1971 K 10 with limited slip differential. Nothing worked except GM additive with GM lube. I always heard it was whale oil. Can you comment, Gene?
The original additive was made from Sperm Wale Oil. At one point the Sperm Whale became off limits and a new formula was made. This was probably thirty or forty years ago.
Posts: 269 |
I've had success with the GM product as well.
31 Chevy Roadster 64 Corvette 76 Corvette 77 Grand Prix
Posts: 1 |
Topics59,071
Posts429,069
