1967 Camaro 327 & 4-Speed Manual Transmission Install Problem - 11/20/20 01:33 AM
Yesterday, Cousin Dave & I were finally (!) installing the 327 and 4-Speed Manual Transmission into my 1967 Camaro Coupe. It was going fairly well - we didn't run into the firewall or anything else while dropping the combination in. Engine mounts lined up perfectly, but when I went to mount the transmission to the crossmember, I'm about 2 inches short of the transmission mount! See photo. From everything I've seen, there is only one crossmember for a small block installation, no matter if it's a manual or automatic transmission. While this car started life as a 6 cylinder with a Powerglide, it looks like the crossmember was still the same. What am I missing? Why doesn't my transmission line up with the crossmember transmission mount? The Muncie 4-Speed transmission has the 3885010 case with a 3846429 tail shaft. I've also compared the 429 tail shaft to a 3857584 tail shaft (difference as to where the speedometer cable is attached), but they seem to measure exactly the same in terms of length and position of transmission mounting. Is this potentially a Muncie vs Saginaw 4-Speed transmission issue?? Any thoughts appreciated!!
