headlight buckets - 02/24/09 04:01 AM
My question is about the mounting lugs for the adjusting screws and springs for a 69 A body with quad headlamps. Should the inside (bright) set be slightly different in orientation with the third screw lug (w/o adjuster) about 20 degrees offset to the other bucket? It looks like the correct setup should have two sets of two different buckets and not one set of four? Does anyone have a picture of a correct headlight bucket assembly w/o the headlights and trim rings installed?
