Check both battery (made up of 6 2 volt cells) and the alternator.
You can check the alternator by (while the car is running, place a piece of metal (small flat wrench will do) on the back side of it. If it is charging, he wrench will be drawn (as in a magnetic pull to the alternator body.
You may have been running on just the battery and depleting it and then< if it is week or the alternator is not properly charging, ending up with insufficient power next time you rely on it (battery).
As others have suggested, I too, believe you may have a bad battery. Only owing to the history of such bad batteries suggest that something may be causing, contributing or acerbating to the problem.
Hope you find the culprit.
Best,
Charlie
