48 Business Coupe Filler Neck Removal - 12/29/22 08:11 PM
Hey all!
Hoping to find some obscure knowledge on the 48 Business Coupe. I believe this matches the sedan delivery as far as what I am after.
Briefly: Does the 48 Stylemaster business coupe's filler neck really just unbolt from the gas tank as it appears to?
More details: due to my car going through fuel filters like their coffee filters, I am having a new stainless steel tank made this winter for my 48 Stylemaster Business Coupe. Luckily someone (Rock Valley Auto - RVA) knows how to make a tank for the business coupes. Unfortunately, they don't have schematics on the filler neck, which I would also like to have replaced as it too is looking a little worse for wear on the inside. And unfortunately, nobody sells a replacement neck for the business coupe.
RVA offered to make a new filler neck though, they just need me to send them mine. Well, I have gone down to the neck before and indeed just got the wood back up so I could look at it again, and unlike what I can find of other 48 Chevy models, it seems the business masters neck is bolted on? There are two nuts on two bolts that appear to hold it in place. I can see the separation between the base plate of the neck and the tank, and I know for semi-fact that the neck is held in place by its connection to the tank, and nothing else. So, it would certainly appear at first glance I can undo these two nuts, and ta-da, the neck is off.
Well, I tried, and they don't have an interest in budging so far. I think someone coated the outside of the tank in something which has effectively blocked the threads as well as frozen the nuts in place, so I still think this is doable with some cleaning. But, I thought it worth asking to make sure this is indeed supposed to be removable before I try anything drastic. None of the manuals really clarify if this is possible from what I have seen - some of them mention removing the neck but it's not clear what exactly they mean by that.
http://chevy.oldcarmanualproject.com/shop/1942_47/4247csm801.htm
http:/
