running bad. HELP!!!! - 07/08/14 04:15 PM
I bought my car in boxes. I have been struggling with the engine. Starts good and idles O.K. but when I throttle up it dies. I have the valves good. the carb is cleaned. The distributor is a major question. The body was in bad shape. Bought a new body and installed the guts from the original. I have spark but the spark follows the adjustment rod to the steering shaft. At idle it runs but I can see spark where the rod connects. I have put a paper gasket under the arm at the dist. It seems to have solved the spark issue or has it? Any tuning tips would help a lot. Getting very frustrated at this point. I also have a newer coil with a condenser. Not sure if it is installed right either. Can someone explain how the distributor is supposed to be assembled. And how the coil is to be hooked up. Thanks Paul
