VCCA Home
Posted By: 51steve best way to install gaskets? - 12/18/08 12:38 AM
Hello Gentlemen,
Once again I have a mechanic 101 question for all of you.
Before I button things up I dry fit everything to make sure everything lines up, enough bolts etc. However- as I was dry fitting the oil pan gasket set it seemed that the thick gasket that fits in the front and rear main bearing cap (no, I don’t mean the oil seal) seemed too snug. So I called the part supplier to ask them what I should use to make it easier to install the gasket. They said to soak the gasket in oil. So I did. Now someone else (a shade tree like me) said that instead I should have soaked them in water? To me water on metal doesn’t sound right!
So I ask you (I should of in the beginning)- How should I install the other gaskets (such as pushrod cover, valve cover, and oil pan)? Should I put a film of oil on them before installation, install them with a coat of RTV (forget about removing with the gasket intact) or soak in water?
Thanks again!
Steve
Happy Holidays!
Posted By: Junkyard Dog Re: best way to install gaskets? - 12/18/08 02:00 AM
When a new old stock cork gasket has shrunk in size due to age, soak it in hot water and the gasket will usually go back to its original size.
Posted By: Chev Nut Re: best way to install gaskets? - 12/18/08 03:33 AM
The modern replacement gaskets tend to shrink less due to the fact that there is rubber/neoprene other mixed in with the cork. The end pan gaskets are a big problem due to the fact that the material is rather stiff or solid and not pre-bent to fit around the main bearing caps. I would first soak it in water to see if it soften and also pre bend the corks by taping them around a can or bottle for a day.
The original pre-curved all cork gaskets wol fit into the grove and stay in place very well. I would think tha soaking them in oil would cause them to expand if anything, making matters worse.
For the other gaskets I never use sealers or such. If necessary to hold them in place I used grease. Makes it much easier to clean up the next time.
I have used some 50 year old all cork gaskets that had shrunk almost an inch. Soaking in water for a few hours brings them reight back to size. This should not be necessary with new gaskets.
Posted By: 51steve Re: best way to install gaskets? - 12/22/08 10:51 PM
Thanks to all,
My snail pace is taking me closer to buttoning up the engine! I'll be sure to post another mechanics 101 soon!
