Chatter from trans or clutch? - 08/13/23 10:40 PM
I have a 47 Stylemaster that is giving me lots of chatter in first gear when taking off but smooth in the other gears when the clutch is depressed. I understand the need for new motor and transmission mounts with the proper alignment from the manual.
I looked that up and don't understand this portion:
3. Check the clearance between the transmission cross member and the "U" section plate (pasĀsenger models only). This clearance should he from .005" to .015", equally spaced fore and aft. If the clearance exceeds these limits, remove the mounting and bend the "U" section plate until the clearance is within the above limits.
What is the "U" section plate they are talking about? Pic would have helped me...visual guy!
Thanks for your time and advice.
