I am in the process of installing a T700 behind a 235 in my '47. At the moment it uses the front engine mount and the bell housing mounts. With theT700 , I will lose my rear mounts, so I will have to use my side mounts
with appropriate mounts to the frame. Before I go making templates and making some up, does anyone already make these to go on a 46-48 frame?
Guess I need to know what a T700 may be.
A 3 speed + over drive GM automatic transmission. Came out in 1982 and was a disaster, used and improved for many years later.
The T 700 was a later overdrive version of the Turbo 350 and Turbo 400. The one I am using is the manual
Valve body version, which has the Chevy small block bolt pattern, and there are adaptors available to mount it on earlie sixes.
Your question may be more readily answered in the PERSONALIZED MODIFICATION SECTION of this forum.
Click here:
https://vccachat.org/ubbthreads.php/forums/86/1/personalized-modifications.html
I put a 700 in my 41 and I modified the trans crossmember. When I get it out of storage I could sent you pictures if you like. There my be some One making a crossmember but I never looked.
Thanks BobG, I have done that. Dens 41, I had a look at the original crossmember, and I reckon I could leave most of it there, and cut out the middle, so I could make a bolt-in piece to match the rear T700 mount. But if you have pictures of it , that would be handy. thanks
When we get home next week I will get the car out and take pictures. Send me your email and I will send the pictures that way.
Denny
