Vacuum Shift Question - 02/13/18 11:08 PM
I need to replace the vacuum cylinder on my 41 coupe. I think the guts are worn out. It jumps out of gear, etc and I have worked on it before. I have a NOS one that I can put in so that's no problem. The rubber bushings where it attaches to the bracket are toast. What I need to know is how thick each of them need to be and whether I cam make some out of something like maybe struct or ßhock bushings.
Seems they need to be about 5/16 inch or so thick. Maybe less. Don't know.
If any of you have made up replacement rubber bushings please let me know how your method worked.
The reason I posted this here is because the issue is the same through more than one forum.
Thanks a heap,
Charlie
Thanks a heap,
Charlie
