Valve adjustments - 07/31/22 05:05 PM
I know this has been gone over over and over again, but I need diagrams with numbers. I keep reading references to numbers and sequences but I don't know what the directions are referring to. I have some slightly bent pushrods and it was recommended i remove them and straighten on a flat surface so I am at that point but not sure how to proceed.
-Is it possible to install the distributor 180 degrees out of phase? I am using my hand crank to get the crank in the correct position to adjust valves. Any advice is appreciated as usual.
-My hope is to straighten pushrods and get the car running once reassembled and if further adjustments to valves need to be accomplished, I can move forward from there
