1937/1938 wheel pinstriping - 10/29/20 03:13 PM
I sent some '37/'38 wheels off to the sandblaster. I saved one back because it had red pin striping which I assumed to be original. Circling the hub cap was a wide stripe with a hairline stripe both inboard and outboard of it. There was also a stripe on the rim, not quite centered on the valve stem hole. Is this correct striping?
I began to doubt that it was original when I power washed the wheel and some black paint came off to reveal gray primer below. The stripes could be correct but not original. If they are not correct, I will not bother saving this wheel for a pattern. Please help.
