VCCA Home
Posted By: Timmins57 1937 Hi-beam indicator - 09/23/14 08:20 PM
This might be a dumb question but were there high beams on the 37 Chev. My car has hi beams but I can't find a high beam indicator in the dash so I am wondering if there is one or not. I was getting flashed the other night on my first cruise with the car in the dark so I figured I'd better fix the problem!! Besides ... my father always said there s no such thing as a dumb question only a dummy that never asks!!!
Posted By: green427 Re: 1937 Hi-beam indicator - 09/23/14 08:43 PM
Doesn't look like it...
http://chevy.oldcarmanualproject.com/chevyowner/37om05.htm
Posted By: Tiny Re: 1937 Hi-beam indicator - 09/23/14 09:00 PM
It was an accessory that clamps under the lower dash lip. If you find one be ready to dig deep. They are rare and command ungodly prices. You can see mine below to the right of the steering mast. If you are interested I made one, that I used until I was finally able to buy an OEM piece, that I would sell. The only similarity to an OEM piece is the function and mounting. I used a window blind end bracket and a small 6v red LED. If you're interested I'll take a couple of pics and send them to you. Or if you want the pics so you can make your own I can do that too. Just let me know.
Posted By: Chev Nut Re: 1937 Hi-beam indicator - 09/24/14 12:02 AM
The first year to have a highbeam indicator built in was 1939.
For now you will haave to pull up to wall and see when the beams are the heighst and go from there.
Posted By: old216 Re: 1937 Hi-beam indicator - 09/24/14 01:07 AM
That is quite interesting that 1937 Chev headlights can be too bright for driver's in this day and age.
Posted By: Rusty 37 Master Re: 1937 Hi-beam indicator - 09/24/14 02:18 AM
Interesting question! Earlier this month I installed a new wiring harness in my '37 Master Coupe. I noticed that the complete harness did not include wiring for the high beam indicator.
I have since determined that the one in my car is indeed an aftermarket item mounted in the dash to the left of the instrument panel. It has small red lens with a dash bulb behind it. Yes, I did replace the wiring to it just to be sure.
Posted By: Ed_Osier Re: 1937 Hi-beam indicator - 09/24/14 02:43 AM
Like Tiny, I made my own which is very similar to the original accessory it functions very well but is not correct for show. It clamps below the dash left of the steering column.
Posted By: tonyw Re: 1937 Hi-beam indicator - 09/24/14 12:07 PM
Some where in the archives I seem to remember someone posting that some Chevs had a small indicator reflector attached to the headlight itself. I dont know how it would differentiate between high and low beam though it would indicate that the headlights were working.
Posted By: Chev Nut Re: 1937 Hi-beam indicator - 09/24/14 12:12 PM
That was to confirm that the ligt was working....1937-through early 1939.
Posted By: green427 Re: 1937 Hi-beam indicator - 09/24/14 12:31 PM
I still remember as a kid that my Dad had to leave the high beams on in the '38 in order to see anything at night. After the entire wiring harness was replaced and NOS bulbs were installed, the difference was very noticeable.
Posted By: Tiny Re: 1937 Hi-beam indicator - 09/24/14 01:31 PM
There are bulb alternatives available to get much brighter headlights & still use the prefocus base bulbs. In '38 the standard bulb was the #2320 w 21cp low beam & 32cp high beam. An option is the #2330 w 32/32 but a better option is the #2530 w 50cp high & 32cp low. I found a lifetime supply of NOS #2530s on ebay a year of so ago. MUCH better high beams at night. If you search ebay for "2530 bulbs" then click ebay motors you'll find a few listed right now. One seller is selling Chinese repops for much less that the NOS bulbs listed. Of course the effectiveness of any headlight depends on the condition of the reflectors.
Posted By: modiol Re: 1937 Hi-beam indicator - 09/24/14 04:25 PM
Here is a picture of the High Beam Indicator light for a 1938 Chevy. I believe the one for the 37 is suppose to be a woodgrain or marble pattern.
[Linked Image from i10.photobucket.com]
Posted By: Timmins57 Re: 1937 Hi-beam indicator - 09/24/14 09:00 PM
Thanks for all the info. I have something to hunt for at the next flea market. I didn't think the headlights were all that bright but I guess the other driver thought so!!!
Posted By: junkyardjeff Re: 1937 Hi-beam indicator - 10/01/14 01:43 AM
I would think someone would be reproducing that part by now.
Posted By: Style Re: 1937 Hi-beam indicator - 10/01/14 10:16 PM
Just the sort of thing I&I do .. might ask the question..
Posted By: junkyardjeff Re: 1937 Hi-beam indicator - 10/01/14 11:44 PM
Even though my 37 is 12 volts the original style bulbs on high are usually not enough to bother oncomming vehicles but would be nice to know when they are on since I have a habit of hitting the dimmer switch and not even knowing it.
Posted By: Tiny Re: 1937 Hi-beam indicator - 10/02/14 12:00 AM
Tomorrow I'll take a few pics of my home made indicator & post them in case someone want's to make their own.
Posted By: junkyardjeff Re: 1937 Hi-beam indicator - 10/02/14 12:01 AM
I would like to make one.
Posted By: Tiny Re: 1937 Hi-beam indicator - 10/02/14 01:50 PM
Everything you need you should be able to find at your local hardware store. You'll need a roll up window blind end bracket <CLICK> , a small flat reinforcement bracket <CLICK> , a thumb screw, two nuts same thread as the thumb screw, a 6 or 12 volt (depending on your application) LED and a dab of epoxy or JB Weld.
First drill out the center of the roll up blind bracket to accept the LED. Second bend the flat bracket into a "U" shape. Third sharpen the end of the thumb screw to a point. Bond the two brackets as shown using the epoxy or JB Weld. Bond one of the nuts to the bracket as shown. Attach the LED and solder the ground wire to the "U" shape bracket. Screw the second nut onto the thumb screw (used as a jamb nut if necessary, if not necessary you can discard it). Extend the LED hot wire with a light grade wire (I used speaker wire) to reach the high beam side of the dimmer switch. Assemble as shown, attach to your lower dash lip and enjoy.
Posted By: solafide Re: 1937 Hi-beam indicator - 10/17/14 01:34 AM
http://www.ebay.com/itm/Vintage-bak...ries&hash=item4188ce681a&vxp=mtr
Posted By: Timmins57 Re: 1937 Hi-beam indicator - 10/20/14 09:04 PM
Thanks for the design. I'm going to try to make the indicator light.
Posted By: junkyardjeff Re: 1937 Hi-beam indicator - 12/06/14 01:17 AM
I just got a new in the box aftermarket high beam indicator off ebay for 10 dollars to put on my 37,I was hoping to find a original but I doubt I could have found a NOS original version for 10 dollars.
Posted By: Ed_Osier Re: 1937 Hi-beam indicator - 12/06/14 06:39 AM
The originals I have seen go pretty high $. I made one for my 37 using the frame from an old clamp on under dash heater switch, with a red light mounted in it. I just used the frame and threw the no good switch away. It works great and looks similar to the real thing, I really like it and can tell when my lights are in hi beam.
Posted By: junkyardjeff Re: 1937 Hi-beam indicator - 12/06/14 01:22 PM
I was going to make one when I got bored over the winter but when I found one for 10 dollars I got lazy real quick.
Posted By: Style Re: 1937 Hi-beam indicator - 12/06/14 09:45 PM
http://www.ebay.com.au/itm/281274232331?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
have purchased these 6v led's on line .. red/orange/blue etc.. very good quality and very bright .. was thinking of doing a reproduction of the original with one of these fitted inside .. turn the molded piece out of colored nylon/plastic on a lathe ... next project
Ollie
ps you have to insert .com into the URL
Posted By: junkyardjeff Re: 1937 Hi-beam indicator - 12/08/14 10:54 PM
My high beam indicator arrived in the mail today and the box is small enough that I might misplace it until I can get the truck back to my main garage to install it,the red light is smaller then I thought it would be but might not need to be to give off enough light.
Posted By: green427 Re: 1937 Hi-beam indicator - 01/02/15 02:42 PM
I was on ebay last night browsing new items, and someone is selling a NOS hi-beam indicator, looks pristine...they only want $695.00 for it....... hello2
Posted By: Tiny Re: 1937 Hi-beam indicator - 01/02/15 03:13 PM
It's been listed off & on for quite a while. Eventually he'll either find someone who "MUST" have an OEM part and will spend anything to get it or he'll give up. BTW if you think that's expensive try shopping for OEM 37-38 fender skirts. You'll swallow your teeth even if you don't have false teeth. I passed up an offer two years ago to buy a pair for $1200. I just couldn't justify that much money. I've since seen pairs in worse shape on ebay not meet reserve @ $3000 bid. As much as I'd like to have a pair they still aren't worth that kind of money to me.
Posted By: Fleetboy Re: 1937 Hi-beam indicator - 01/03/15 02:30 AM
Just a few weeks ago I saw some skirts for sale at $9,000 !!!
Posted By: green427 Re: 1937 Hi-beam indicator - 01/03/15 03:31 AM
I have a set of original gunmetal '38 skirts that I am not crazy about....if they were actually worth that much...I would not hesitate to sell them...
Posted By: Tiny Re: 1937 Hi-beam indicator - 01/03/15 02:20 PM
If you ever decide to sell them and don't want to retire the national debt with the price let me know. laugh
Posted By: junkyardjeff Re: 1937 Hi-beam indicator - 01/03/15 02:24 PM
Wow almost 700 dollars for a high beam indicator!,my 10 dollar aftermarket one will do just fine.
