Universal joint, closed driveline function? - 09/17/13 01:02 AM
I just replaced the clutch in my 1940 chevy, and now have a major leak/vibration coming from the u-joint/bell sleeve area.
I pulled the joint apart, and found a large amount of "end play" between the "spider" and the two "yokes". (nearly 3/16 inch). The bearings all seem nice and tight. There are no metal shavings or other indications of wear. I found a used replacement from an good running car (new replacements are not presently available); and it has the same play.
At this point, I am wondering if my problem is with the bell sleeve? If it is fixed rigidly to both the transmission and torque tube, the u joint should be centered and not wobble. Would still need to have the bell be free to rotate in the transmission case however.
Could it be that I just haven't tightend the sleeve sufficiently?
Has anyone else encountered this issue? and if so how have you resolved it.
