Underneath a 41 - 01/25/12 10:53 PM
Weather permitting, I plan on starting to do some more work underneath the 41 tomorrow. After installing a new master cylinder (if I can ever get the pedal lock key removed so I can take the old one out) I plan to do some spray paining with black semi-gloss. Anyway, I think I understand the parts that do not get paint but check me out and let me know if I'm about to err in some way. My mind tells me that the following parts do NOT get paint:
a. Master cylinder
b. Brake lines
c. Fuel lines
d. Spring hangers (from frame brackets down)
e. Transmission
f. U-joint (sleeve and bell or any parts from torque tube forward to bell housing)
g. Vacuum assembly (how about the bracket and breather to frame?)
h. rear springs and metal covers
i. Gas tank
j. Steering sector (not sure about this one)
k. Stabilizer links and bolts
l. Gear shift links (not sure about this, either)
m. Emergency (parking brake) cables
The above is about I can think of that doesn't get either semi-gloss black or engine paint.
Input will be greatly appreciated.
Charlie
a. Master cylinder
b. Brake lines
c. Fuel lines
e. Transmission
i. Gas tank
Charlie
