Have gotten the motor # A228 302 731 from the engine and have determined that the size of the truck is 228cu. The motor casting GMC - 5 # 6107326 which I think makes this engine a 1952. The cab # is 253 22 S 25.. which I think means it is a one ton vehicle. Does any of this make sense? Can anyone provide any more information or correct my research errors.
http://www.oldgmctrucks.com/photos/EngineSpecs_Pg1G.gif A indicates the size of the cylinder, rod, and, crank journals which in this case is + 5 thousandths on cylinder bore and - 10 thousandths on the crank and rod journals.
228 indicates the engine size
302731 is the regular sequential production number of the engine
