VCCA Home
Posted By: BearsFan315 1/2 Ton vs 1 1/2 Ton 1929-1932 Era - 04/17/13 12:12 PM
Ok, just wondering what the main differences are between a 1/2 Ton and a 1 1/2 Ton pickup in the 1929-1932 Era. I know that the Frame is Beefier and Reinforced, Different Rear Springs, or Additional Rear Springs. Is there a Different Rear End (ratio), Transmission/ Gears ?? What abour Tires & Rims ?? Most I have seen have the same from Wheels, 6 lug, but the rear are 10 lug. Are they the same style, utilizing hte same tool to remove, change tire/ inner tube ??
Just wondering what the upgrades are to the 1 1/2 Ton over the 1/2 Ton.
Posted By: Chipper Re: 1/2 Ton vs 1 1/2 Ton 1929-1932 Era - 04/17/13 02:49 PM
1/2 ton and 1 1/2 ton trucks share front sheet metal, cabs, front wheels/brakes. Most other parts are different. A search through the parts books will yield the similarities and differences.
Posted By: 29chevy Re: 1/2 Ton vs 1 1/2 Ton 1929-1932 Era - 05/09/13 05:31 PM
While they share a lot of the same front sheet metal the front fenders have a larger wheel opening on the 1 1/2 ton and larger,this is to accommodate the larger wheel used on these model's.
