lil johnny and ChevGene: Thanks for the thoughts and ideas. I'll look for the manuals you mentioned, sounds like good reading at any rate!
Chevrolet:
I'm still scraping Idaho clay and grease/oil/tar from my truck, probably will be for several months. I don't know how long it's been there, but it is REALLY stuck... I've been using diesel fuel, rubber gloves, wire brushes and anything I can find to scrape with. It has taken hours to clean only a few parts.
If you do find your shocks, if they match mine you'll be able to disassemble them (somewhat). My shocks say "Delco-Lovejoy, Made in Dayton, USA"; one of the front's say's "R-1S 1053005" on the frame side, the other say's "1053004 R-35".
I took three of them apart yesterday... I bolted one back on the frame, removed the three screws, then began to pry the cover off with an old screw driver. Before I could get the blade in far enough to it to gently pry the cover loose, the blasted thing spit out the piston, spring, intake valve and the power steering fluid I had carefully poured in 10 minutes eariler. No damage or danger, just a surprise.
When the arm is not mounted in the shock link and attached to the axle, the the back of the cam rides against the cover, waiting for someone to remove the screws. The return spring has a fairly low rate (I guess something like 15 pounds per inch), so you'd have to do something even dumber than I did to get hurt. Anyway, the next one I disassembled I held the arm down by resting it against a pair of vise grips like:
There is no packing around the piston, the piston just slides inside of the cast iron bore in the body. There is little wear on two of my shocks, the other one has the piston rusted in and I haven't gotten it out yet. (This might be the one that get's disected further)
On two of the three I've taken apart, only the gasket and oil HAVE to be replaced. I tore up the screws getting them out though, and the rebuild kits contain replacement screws, gaskets, bushings and pins, so I'll have to get rebuild kits.
If my other set of front arms are worn, I'm thinking of just using JB Weld or some other epoxy to fill up the radial gap so the new bushings have a solid seat to bear up against. Epoxy has a pretty high bearing strength, and is often used as a "liquid shim", so I think this should be OK, but hopefully I won't have to find out.
Here's a look at the valve markings. I think the G 4 C one (front shock) is stiffer, but I'll find out another day.
I'm convinced that the resistance I noticed yesterday is because the power steering fluid is too thick. It has a viscosity between 20 and 25 weight oil. I bought some hydraulic jack oil, and some 5 weight motorcycle fork oil to try. I'll let you know how it goes.
Lenn.
