I need to apologize again for the lousy SEARCH page.
We have been expecting a complete overhaul of it for the past two years so I've been reluctant to make any changes since they'd be lost upon an update.
In the meantime, hopefully these instructions will help you (and anyone else that reads this). Click
SEARCH on the
Navigation bar at the top of the page.
Click on
ADVANCEDHighlight the forum that you want to search - example: 1937-42
(Note: Select multiple forums by holding CTRL when you select each.)
In
KEYWORD SEARCH TERMS enter what you're looking for - example:
1938 chassis(Note: Must be greater than 3 characters, but use as few of words as necessary.)
Under
DATE RANGE, blank out the "Newer than" box.
Change "Older than" to something - example: 1 Year(s)
Click
SUBMIT at the bottom.
----IMPORTANT-----If you follow the instructions above, you'll see ALL responses that match <1938>, and all that match <chassis>, and all that match <1938 chassis>. That's probably
NOT what you wanted.
So if you only want results that
includes BOTH words, then
add quotations to the search term - example "1938 chassis"
