1927 National truck with a 1928 engine leaking gas. - 04/06/23 11:34 PM
I am working on a 1927 Chevy national with a 1928 engine in it.
I am trying to bring it back to the original fuel system. I removed the electric fuel pump and modern carburetor.
I bought a rebuilt Stewart’s vacume tank and installed a RAKX-O carburetor kit.
I installed new copper tubing and made sure the connections were tight.
Problem, the engine will run fine, speedup quickly, and then try to smooth out.
Is this normal operating or is there an air leak. I am not use to working with a vacume tank system.
The other issue is that I am dripping gasoline from the carburetor bowl and the fuel supply connector to the carburetor. I cleaned the fuel supply connector to the carburetor and installed new gaskets and fuel metering pipe. It has a very slow seepage at the base of the fuel supply connector to the carburetor.
The other leakage is that the carburetor bowl is seeping. I put on a new bowl, new bowl nut and gasket. I have snugged up the bowl and it seeps. How far to turn the nut without stripping the threads the nut screws into to stop leakage?
Thank you for your help- Paul
