Won't Fire up & Start GOOD NEWS 11/4/22 - 11/03/22 11:40 PM
First off I can find no ball on the flywheel looking from underneath with the cover pan removed, and turning it with the flywheel teeth & a screwdriver.... Then I looked four different times through the little window at the pointer, with a flashlight as I lightly bumped the starter, rotating it about 1" each bump... never saw a ball or a bump at the end of the pointer. I looked with bright light at the entire front surface of the flywheel, from underneath.. while rotating it with screwdriver, can not see any ball...
So, I have tried doing a static timing, by bumping the starter, while watching the #6 valves springs/rockers.... rotating until the #6 exhaust valve is just closing, (rocker all the way up) and at that moment the intake valve is just Opening (rocker just starting to go down)..... Then I look at the #1 rockers/valves and the are both closed (rockers loose from valve stem)....
Now I have noticed that the #6 & #1 valves/rockers seem to always line up, as mentioned above... SEVERAL times in this configuration in ONE full Revolution of the flywheel......
Question; How do I know which alignment of this configuration do I set the distributor rotor to # 1 post/wire.....????
Here Is what I have done thus far..... Rebuilt carb (tested by Dean Echols to run as set), rebuilt fuel pump with modern diaphragm), New plugs AC Delco R45 ....set at .32 (are these plugs correct??) New solid core plug wires, new Dis cap and rotor and I have tried 3 new condensers......
Cranking with the choke pulled all the way out... Nothing .... cranking with the choke open, and short spay of starting fluid.... nothing... cranking with gas pedal 1/4 depressed... Nothing..... cranking and choking with hand on carb,,, Nothing.... all these were tried at different times on different days after sitting all night
Before I cranked each time I checked for good spark at the plugs... got good spark also good spark at points & end of big coil wire... Why won't it Fire...??? Why won't it Run for me...???? any help would be appreciated.
