I have a question about engines 216 & 207 - 06/21/22 12:53 AM
If I was to consider putting a 216 from a 1947 chevy into the 1934 Master sedan..... would the engine bolt to the 207 bellhousing and be able to use the fly wheel, pressure plate, clutch and throughout bearing...??? and would there be a lot of fabricating of motor mounts etc....
.... and right now there is also, a 1936 chevy 206 engine for sale that is running well, for $500 on Marketplace... Will the 1936 207 engine need to come from a Master or would it have the same 80 HP even if it came from a 1936 standard.....?? and It would bolt right up as though it belonged there.... Correct...??
I Love my 1934 Master town sedan... I just want to get her running... and I am going to remove and clean out the gas tank, flush the radiator, to see how it flows... and check the flow of water, through block,........ and drop the pan and clean the oil pump intake... and then check the carb... and order gaskets for pan, valve cover. fuel pump, carb, and water pump... to start a through inspection, cleaning.. to discover what 'She' needs to get running again...... Please answer my questions about the engines.... Thanks, Sunny
