Windshield Sealant - 12/27/18 08:04 PM
The Assembly Manual for Advanced Design trucks states that GM #3686628 sealant should be used between the windshield glass and the weather strip as well as between the weather strip and the body.
The '48 - '51 truck shop manual simply states use 3M weather strip adhesive in both locations.
What is today's equivalent of those sealants? Is it an application for a hardening or non-hardening sealant/adhesive?
Checking older posts I see that some people use the 3M Black Super Weather Strip Adhesive. However the 3M specs on that specify it is for bonding rubber to metal. Will it seal to glass?
I also see that there is a 3M product auto bedding and glazing compound that is intended to seal weather strip to an auto body. It is a non-hardening sealer.
Thanks for the help!
