Here are the dimensions for the seat bottom springs on a 1926 touring car as near as I can tell (they are upholstered now). These are the dimensions at the base and there is a slight overhang at the top (seating) surface.
Front seat bottom:
36 inch wide at rear, 37 inch wide at front
1.75 inch radius at front corners, 3 inch radius at rear corners
6 inch high at front and 5 inch high at rear
Rear seat bottom:
43.5 inch wide at rear, 44 inch wide at front
7 inch high at front and 5 inch high at rear
Note that the frames for the seat bottoms (part of the structural body wood) are not parallel to the floor. This is most noticeable on the front seat base which is higher at the front than the rear.
Hope this helps. Tom
