The former owner of my car painted all the door handles, escutcheons, and window cranks. Can anyone recommend a plating shop to rechrome them, or is it more economical to buy reproductions?
There is a chrome shop north of the border in Quebec not far from me here. I can get their address and phone number if you're interested. Wasn't sure if you wanted to get involved with customs or not. They are very good and highly recommended. In fact they do chrome for S&S motorcycle engines.
The advantage of repros is they won't break. The problem is the finish is incorrect. the Interior handles and escutchoens should be nickel finished and not shiny nickel but dull which is called a "butler" finish. Chrome is incorrect for a true restoration and the repros are stainless which should also be nickel plated to be true to original. Of course this all depends on what the owner really wants for their car.
That they don't break is important. The handles for my 32 were replated in Canada (Quebec) but the integrity of the splines was damaged most likely when the old plating was stripped. They look great but are totally useless except for decoration as all the splines stripped on the first use. If replating be sure the shop doing the work knows how to do the job properly.
Here is the chrome plating shop in Ormstown Quebec that I referred to in an earlier post. I personally can't refer them but I have been led to believe that they are exceptional in their workmanship. Good Luck
