Fuel gauge resistor needed - 82 C10 - 01/12/19 02:24 AM
My '82 C-10 has a fuel sending unit measuring 98ohms. The highest I can find is 89ohm. Will that work correctly? If not, what can I use (or where can I buy) to get an accurate reading?
Also, I need to buy a new wire harness for my oil switch. The coating is failing and exposing some of the wire. The switch is two prong, but the switch wire harness has three wires. I think two blue and one tan.
