useful modification for charging your 6V battery - 10/24/15 06:33 AM
hi there,
I finally installed a solution to the problem of charging my 6 volt battery under the seat of my Chevrolet standard 4 door sedan.
I kept reading about an "Anderson plug" and it intrigued me as to what is was. Its a plastic type electrical plug that when reversed upside down fits into the other half which is exactly the same molding of the other, yes its an amazing piece of engineering.Clever stuff indeed.
I attached two wires to one half of the Anderson plug and the other ends to the battery terminals. Drilled a hole in the floor, pocked the wires through and screwed the Anderson plug to the base of the seat under my legs.
Cut the clips off my 6 volt battery charger and attached an "Anderson plug to the wires.
Now when I wish to charge the battery, I just open the door and plug in the Anderson plug to the other mounted on the front of the seat frame and start charging the battery. No more struggling with removing the front seat, carpet and floor hatch to attach the charger leads to the battery.
Best mod made this year and there have been many.
My other best mod this year is fitting a 6 volt petrol pump in tandem with the mechanical pump, to assist with percolation of fuel on summer hot days of 35 deg C and above. Works a treat. Only turn it on to clear vapor lock if it happens.
The end
Peter
The end
Peter
