Hi jorb -
The three terminals on your '54 truck ignition switch are --
> Ignition (Coil & Fuel Gauge)
> Power Source (Ammeter)
> Accessory Terminal (Empty, switched with ignition key)
I have the terminals connected like this on my "stomp starter" '54 3100 with the ignition switch installed in the dash and looking at it from the driver's seat:
> Left terminal: Coil and Fuel Gauge
> Bottom terminal: Ammeter
> Right terminal: Heater blower and Cigarette lighter - so that it will switch off anything plugged into the lighter when the switch is turned off. Cig lighter was probably not switched originally)
I had it connected like this last year, and worked OK. Not sure if it is important what terminal is connected to the power lead.
![[Linked Image from i149.photobucket.com]](http://i149.photobucket.com/albums/s50/lonnieinorlando/54%20Chevy%203100/Electrical/GaugeSchematic.jpg)
FYI - The horn bypasses the ammeter because I was afraid that it would damage the meter when tooted. Since then learned that it won't, so I will wire it as shown on the Chev wiring diragram next time.
If you use any high amperage accessories connected to the acc terminal of the ign switch, you may want to connect a power relay to the ign sw and the accessories to the relay to avoid arcing the contacts in the ign switch.
- Lonnie
